B
Here's my set up, 06 m7 153 rkt head and slp twins, primary has 67g weights and a slp black pink (120/340), secondary is a straight 40 with a team black white, rider weight is about 240 all geared up and elevation from 3-6k. Here's my problem, on the road or beat path on a hill the thing rips and pulls right at 7900 on a hill and 8100 on the road with not much load, but when on a powder hill or under load it will start good but load up and bog down and barely get any track speed. I'm wondering what to do to fix my problem. I have an AC gold spring I was using with the stock pipe but changed to the slp black/pink to get my rpms up for the pipes, should I go back to the gold and drop weight to get the rpms up? How many grams do I need to drop to gain 5-600 rpm? Do I need a stiffer spring in the secondary to counter act the steeper cam or just change to a 36? Not really sure which way to go any advice would help out, thanks.
