'16 Axys with MTNTK Turbo: engine starting questions
Hi all. First test ride yesterday with my MTNTK turboed '16 axys: great power, zero stuttering or bogs, and very little turbo lag. However, it is hard to start first start of the day. Takes me 10-12 pulls, and that was sitting overnight in a fairly warm (50*) garage. After sled is warmed up to 100*, I can shut it down, and then restart it a couple minutes later with only one pull. Leave it sit for 10 min or longer (outside temps on the hill were 10 degrees) and then it takes 3-5 pulls, most of the time partially opening the throttle to get it started. Nate from MTNTK said unfortunately this is normal for the Axys. You guys experiencing the same thing? If not, you have any helpful tips? Right now I am concerned about trying to get it started after it has sat outside all night in 10 to 20 degree weather.
And what weights you running? I have my boost turned all the way down and was still over revving (8450) with 72 gram Polaris weights at 5500' elevation, dry fluffy snow conditions.
Thanks.
