Fuel may be required...
Deaner, I suggest you add some fuel to the mid range. My wife's M8 has and SLP pipeset and high flow intake - I ended up adding fuel in both mid and top end (riding at 5 - 9000'). The sled is happier with the extra fuel (better performance). I am somewhat hesitant to call ou numbers as every engine is slightly different, and the speedwerx intake flows a bit more air then the SLP setup, and I've also added STM exhaust valves and an RKT head to her machine. If it was my sled, I would run a baseline with the stock pipe to establish EGT's over varying RPM and load, then intall them on the SLP set and tune from there, but read plug color and piston wash to confirm. PM me if you want to talk tuning.
