M8 162 Holtz fit an 06 M7 153?
sbosmt
New member
Oct 14, 2008
134
2
18
Bozeman, Montana
I might have a chance to swap a holtz rear suspension off an 07 M8 162 and wondering if it would fit on my 06 M7 that is a 153. If it would fit my m7 would it make a huge difference and what is worth if i do all the swapping? It is used but in good shape.
thanks
B
5
18
Why don't you change the rails across and use it as a 153 holz?? Then you don't have to change your tunnel or nothing. It'll bolt in but you'd have to use your rails.
B
Dec 21, 2006
1,760
173
Yes, it will. Make sure that you use the correct hole on your relocation bracket as it will be different than what you are currently using
