Rode against my buddies "new" '03 900 yesterday. About 2' of powder with a crustier layer underneath. I pulled through a moderate climb with sled at 8000 rpm and got stuck up a steeper section. His 900 blew right past with ease. This happened twice. On a bigger hillclimb, he was two to three sled lengths above mine. I thought an M would easily beat a 900. Here are the numbers: '06 M-7 LE (135 hp, 162" track) - about 565 lbs. wet or so. His 900 (150 hp, 151" track) about 595 lbs. wet or so. I am 25 lbs. heavier and had a 15 lb. backpack. Just by the lb/hp numbers, and just using bodyweight difference, I am at 4.48 lb/hp. He would be at 3.97lb/hp. Alone this is quite an advantage for the 900. However, I thought the extra track length and geometry of the M was supposed to make it "go" better. Could clutching be an issue? Or is it just straight pounds per horsepower in this case? Any thoughts? Thanks.
