I have a 06 m7 162, I have ridden a few m7 and they do not have the snap of the 800 or 900 mc. I am coming off a 800 mc that will pull right from the start, this m7 need a few seconds to get going. What can be done, I do have a rkt head I think I need to address the clutching or gearing. It has the OVS sec system. Back shift is not good as well, if I can stay on the pipe it runs very well.. All stock on intake and no vents, maybe she is heating up too fast. Thanks for any input.
I've got a theory on the M7 sluggish backshift and low end power and how to clutch around it. I have tried many weight, helix, and secondary spring combinations. Many combo's were better than stock, but still not great. The best backshift and clutching around the low end power problem was with the heaviest shift rate primary spring with a fairly low preload and 65 G weights (8-10000') I think part of the problem is that AC doesn't have the range of springs that Polaris and the aftermarket has. The Primary spring I used with the best success so far was the Polaris Black. I believe the shift rate is heavier than any stock AC spring. I am going to test my theory next weekend with the Polaris Black/Green. This spring has roughly the same engagement preload as the AC Yellow/White but the shift rate is well beyond the Polaris black.
I do not own this sled anymore, (sold it to my dad) but since it is still in the family, I am determined to make this sled perform.
I should also say that my spider and cover have been machined to accept the larger diameter springs and I am running the stock 10" secondary. Alignments have been done and belts last at least 500 miles, so there are no inherent problems. I'll let you know my findings.
A question to others reading this thread - have you been able to use D&D, SLP and other aftermarket springs without problems and not machining the cover and spider?
