I have a 05 M7 also but all stock (head, pipe, etc.). Does the RPM's go higher then fall back. Watch as you are giving it full throttle, it may peak higher then fall back. It is important to match what rpms the primary will pull (with your engine mods and at the elevation you ride), with what the secondary will allow (by controlling the speed it shifts out). If you are riding in the mountains it is more desirable not to have the midrange shifting out to quickly (this creates a faster acceration for drag racing but makes the sled bog on step hills). Finding the correct amount of upshift that allows backshift and also track speed is the trick and in general you control this with the secondary spring tension. If you shift out to quickly then you tighen the spring tension, to slowly then loosen the tension. So you can control some rpms through the secondary but the real function of the secondary is to control the rate it shifts out. As you increase the tension in the secondary it will slow the shift out and increase the backshift (both favorable to mountain riding) which will increase the rpms if the primary has the power to do so. If the RPM's go higher then fall back your spring tension is too much in the secondary, simple loosen the tension by turning the plastic plate out. But remember now it will also shift out quicker so this may not be what you desire. Your other choice is to decrease the primary clutch weights to bring up your desired RPMs to match your current secondary setting. Sorry for such a long winded explanation but if understand the funtion of the clutches you will be able to fine tune to you riding style, elevation, etc.
I personally ride from 7000 to 9500 feet. Here is what works for me. I started with 68 gram weights and ground them down to 63.5 grams taking most of the weight off the tip area (taking most of the weight from the tip helps the midrange which is great for boondocking and general mountain riding.) The primary spring is the yellow-white (stock spring). The secondary spring is also stock but I have tightened it to slow the shift out. I have also added a shift assist plate in front of the spring so that the secondary spring does not bind from my increasing the tension. I pull 8100 now where as originally from the dealer I was pulling 7600. I have great backshift and midrange performance which M7's are notorious for not having.
Hope this helps.
