P
what should these motors be running for RPMS just bought an 08 that was suppose to be set for 9K ft, would only pull 7300?????? if thats it, its gone
I know a guy that runs 8100 peak rpm for over 2000miles and never had a problem. the slp pipe set creates peak hp a little over 7600 rpm and recomend running 7800 so that if the rpm falls a little it falls right in the power. I like it to run around 7650 to 7700. slp peak torque is around 7400rpm But if you run lower rpm then they recomend you have to know how to set the fuel up because they set it up to run 7800 and if your under that your running to lean with there bd numbers. Mine with a y-pipe and can is running in the 7450(peaking over 7800 on the caption) range and would like it to be a little higher like 7550. these motors can handle 7800 no problem but if your stock you will loose power much over 7400.
How did he get around the rev limiter?
Those rev limiters must not work, blow a belt with the throttle pinned and see where the rpms go.
My 08 is stock and I just gained what I needed. 7300-7400 is not enough! Huge difference between 7400 and 7550 in the way these sleds pull. Call SLP and talk to Dustin about a set of MTX weights and a new primary spring. Don't be satisfied with your sled HOLDING anything under 7500.
Our testing here on numerous M1000 sleds shows best peak HP with either a D&D, SPeedwerx or SLP, pipe, Y pipe, can and better intake, is 7650 when clutched well and balanced in the middle of good climbing and technical boondocking. This is with STOCK gearing.
BB
