hot motor
good fuel, rich fuel conditions, lazy running and insufficient cooling will still cause piston failure, that's why all the engine manufactures have decide that prolonged engine coolant temps above 135 dgrees in a two stroke aluminum snowmobile engine will lead to collapse of the engine....sooner or later.
So.... well.......melted hyfax ? coolant leak? charred head o rings ? disconnected oil cable ? temp light on? do you have a real temp gauge on the sled ? lots of hard snow trail riding ?
Just rebuilt a cat engine for a cabin owner that wouldn't keep his sled off the lake, just couldn't get it through his noggin that hard snow, 2.5" track, blue ice with scratchers down, and doing it over a period of years wouldn't finally ruin his motor......and it did.
His head o rings where hard as a rock and broken, his thermostat was stuck wide open, his oil lines had been so hot so many times they were shrunk down to half their carrrying capacity, no hyfax on the back of the rails and some track clips wore through, both carb boots were brittle and toast, sled looked new, water pump seals were rock hard and leaking, had 1500 miles on it, and only ridden at 1/3 throttle accross the lake to get the morning paper.....many times.
