Another update, wasnt liking my clutch engagement with Team clutch, very harsh with heavy weights (84 base weighted to 87) and even tried a lighter spring. Barely a hundred miles on Bikeman weights and bushings already bad. Belt to sheave clearance is over .130 using belt made for that clutch (084). Is there shims for spacing the sheave clearance on the Team primary? Parts breakdown on clutch doesnt show any different ones that would move sheave closer. Anyhow, switched back to Cat 3 tower with 79 gr Big Dog weights and engagement fixed as belt clearance back to .040 but alignment was way off. The 1100 clutch and M1000 have 1/4 inch offset difference. Checked my 4 tower clutches and they match the Team clutch offset but have proper belt clearance. Another bonus is the Cat clutches are 8.25 inch diameter and Team is 8 inch. They were 1100 application originally. Another lesson to this is to use 1100 clutch for this chassis. Setup a brand new in box 07 1100 4 tower with 68 gr MTX weights with no rivets and going to try it out tree riding at 7K tomorrow. Probably going to need weight added but I tried a different 4 arm clutch with 72 gr Cat weights yesterday in same area and would only hold 6400 on hill in deep snow at 7K, still pulled hard though. Felt great on lake at 4000 ft pulling 7500 RPM. Still would like to get Team clutch working and put a better set of adjustable weights in it but 4 arm might be the ticket for now. Just not a fan of taking fixed pin weights in and out to adjust. Wide range of weight I am trying is because of different weight design, MTX need to be heavier than stock equivalent, Big Dogs run lighter than stock, 72 cat weights were lightest I had with set of 4. Bikeman Goldstar I have no real comment. Looking to end up maybe at 70-72 gr with MTX weights.
