i put 15 miles on my 07 m6 today after i installed a new adjustable helix, and for some reason the white adjustable washer(against spring) turned itself out against the silver plate(on outside of clutch) and then the 3 screws holding the plate came out and now the bolt that holds the whole clutch to the dd is holding everything togethor, the sled isnt drivable as there is no spring pressure, what do i do? everything was tight.it also ate my half of my rollers up.
also should you put any of the old spacers that go against the spring back in the new helix? there were 2 in mine originally.the ones that go on the outside of the spring, opposite to where the shift assist goes.
