iqr problems fuel?
Nov 29, 2014
Started my iqr first time this winter, started first pull idled as it should then went down the bush line 3 minutes into my little rip it died out as if the fuel was shut off, the only way I could get it restated was to put choke on full,then it fired first pull after I took choke off it ran as it should for another 3 minutes and this happened again over and over. Any help would be great
LoudHandle
3,901
2,779
Valdez, AK
Rebuild / replace fuel pump / check impulse line. When you choke it your refilling the float bowls. They are not refilling on there own, as they should.
The Bob
504
84
MN
Another thing to check would be that your gas cap is venting, go ride it again and remove the cap when it dies and try starting it instead of choking it. You may hear a hiss if its the cap. Most all IQR tanks I have dealt with don't have a separate vent. Had it happen with my 8.8 I had on an older IQR of mine.
