Indy Dans Turbo Clutching
pinko
693
123
Wembley, AB
How is Dans setup working in the 5-9K mark? Running the setup that came with the sidekick and feels like there's alot left on the table
KAWGRN
394
83
everywhere
I’m thinking I need to get some more turbo 3’s mine also had no bushings, and kept sticking, so that was my maintainence delima every couple rides pull pins and clean with scotch Brite, will orde up today!
AKFULLTHROTTLE
1,987
1,146
Alaska
Send those in to them
Davajn
245
160
Sweden
www.instagram.com
Anyone tried running another primary spring then what comes in the kit? Got a 155-280 titanium spring collecting dust. Would that be a dumb idea to try it?
A 280 spring would allow me to go some lower grams on the weight.
And when riding at sealvl that could be a good thing. 8psi and above tends to require an insane amount of grams to keep the rpms in check.
TRS
Life Member
4,129
6,290
Cody, WY
You won’t know until you test it. Give it a whirl.
black z
448
255
MN
What he said
I would guess you will not like the engagement as I did not. Make sure your primary is shimmed correctly to help with that.
I ran Indy Specialties new Helix, primary and secondary spring, Turbo 3 weights (74 grams) with 7 lbs on my Silber 14 pro, and it worked fantastic out at Togwotee last week. 8300-8400 RPM, smooth engagement, and cool clutches. Could hold my hand on the primary and secondary as long as I wanted after a long pull, his setup flat out works. :present:
2
Jul 22, 2009
499
76
For you guys that are running the Indy full turbo kit kit, are you finding that you have to reshim the primary or can you get away with leaving that part alone?
562xp
118
47
After you install the kit measure your belt to sheave clearance with a feeler gauge. It should be around .025 inch.
AKFULLTHROTTLE
1,987
1,146
Alaska
I have customers using it on a few different kits including an NA kit. They all love it and it works on all. For a boosted sled you will want to call Jon and ask for the Turbo kit. Let me know Kyle sent ya!
Davajn
245
160
Sweden
www.instagram.com
Anyone running the clutch kit on a MTNTK turbo?
Yes i am running it in my mtntk turboed sled.
Here is some riding from yesterday here in Sweden. Running 6psi at 1600 to 2300 feet, 155-280 primary spring instead of the one in the kit.
75grams weighted pushing 8400 rpm.
Watch in 1080p/60fps :)
https://www.youtube.com/watch?v=dErIVkT4CPc&
Why doesnt the youtube insert link work? Cant imbed the video on the forum :/
sledhead9825
1,195
416
83
Sounds and looks like its working great !!
Davajn
245
160
Sweden
www.instagram.com
How many miles are you getting out of your belts with there setup?
My belt from last years machine went on this years. And its survived 1250 miles before 1 cord started to take a peek out from the belt. Its still intact so i could just shave it off and burn the remaining. Then have it as a spare.
But 1250miles is waaay over what im used to so im very happy.
Yeah it works. Got some low rpm/idle problems with it running to fat. Might have a injector that is leaking. Will see if Mtntk manage to fix that for me.
