J
into seeing more load from the drive shaft/axle? Like when you gear down.
I was also wondering if it was possible myself, to "mask" the reduced load from gearing down through the secondary, the only problem i'm having since gearing down is sorta simple but to no avail so far. Everytime you let of the gas the rollers come of the forward cam and into the reverse part of cam, sometimes banging into the reverse notches and cutting up the rollers pretty good. Even from 10mph to a rolling stop and open up the side panel and it is in full reverse position, not enough resistance to keep it in forward position (compression set-up). Just trying to fix it. Hence looking for ideas
