R
01 800 Gen II RMK.
Installed Koso dual egt's, water temp, tach on her before the last wknd ride.
There are too many mods on this sled to use a jetting chart, so have always done the standard tuning - Look at the plugs and piston wash. Visual checking showed me wash a tiny bit to the rich side rather than lean. Plugs are cardboard brown etc.
Well my egt readings are throwing me for a loop ?!? They are installed correctly, 6" exactly from the skirt, both sides on the twin CPI's. The ride was kinda on the low end of the elevation range I usually ride.
Long story short - babying the throttle I was at around 1000 deg, in the midrange I was consistantly over 1300 deg and even up over 1400 deg. As i got to the real riding and opened her up at some elevation I was looking good at around 1250-1300.
WTF is the deal in the midrange readings? Seems like you could burn down just cruising up the road to the mtn....
Thanks in advance! - RMK
