Sled smokes really heavy when starting---runs fine, and cleans up eventually. Cable is adjusted properly----any suggestions?
I would double check the oil pump linkage arm to see that the hash marks line up at idle and WOT. I did an 03 800 for a guy and it had a single freyed wire on the oil pump cable that pulled up in the housing not allowing the arm to return to alignment at idle. After running it for a while it would warm up and work right, then next cold start it would hang up causing it to over oil. Might be worth a look. Good luck. EW
