fitting M7 153" skid under powder special 600
H
Oct 23, 2010
7
I just picked up a 153" skid from an M7 and I am trying to stuff it under my Powder Special 600 EFI. Anyone have past experience / results and opinions on this set-up? This is a budget build as it is my back up sled. Could I fit a 151" track under it? I am still in need of a cheap track.
Thanks
D
diggerdown
3,452
677
Deer Park Wi.
I can't give you any measurements for hole placement but you will need to put a couple washers between the front tube and tunnel. If you can keep the mounting low enough you may be able to get by running a 2" paddle instead of the notched track, that would be a hugh improvement along with the better and lighter skid. Your drivers are small diameter so a 151 track would fit easily.
