Feels like some thing slipping at top RPM??
MUZBOMB
1,153
95
48
Albeta sometimes Saskatchewan
Hey i was out to day riding and when i cracked it open across a feild i pulls hard and hits 7900RMP's. Once and awhile it slips loose power and if you let off then get back on it is there again? I ride at 2500ft i have a orange/white primary spring with 77g weights and a RKT secondary kit(34/36 helix) with a green sno pro spring. Should i adjust the RKT secondary and put alittle more tension on the spring? Any suggestions would be great. Thanks
smokindave
Canada Moderator
1,950
Calgary Alberta
What are you riding?My guess by your RPM is a M1K.If so what belt are you running and have you checked to see if rivits have come out or loose on cover under secondary?
smokindave
Canada Moderator
1,950
Calgary Alberta
It sounds like you maybe getting a little snow on your clutches causing it to slip.It happened to me after landing on top of a stump which knocked out a couple of rivits on cover under secondary.
Cheers,
Dave
C
Mar 19, 2009
7
I dont have a clue eh?
I ride real powder, hood packed full of it including the clutches ALL DAY LONG! and never have had a slipping issue due to snow, only improper maintainance and set-up or rider error will cause your issue.....some people dont have a clue. thanks.
ski4living
New member
Sep 4, 2008
58
McCall , Idaho
I had the same problem. Pull off your secondary clutch, clean it with brake cleaner. Sometimes belt dust will keep it from opening smoothly. Just did mine and it work great. See if it helps. 5.00 fix
