P
Ive got a 2006 RMK 900. Runs great, excellent power, all in all good sled. Heres the problem. Check engine light bliks five (5) times. It always blinks. on startup, idle, and running. I have replaced the EGT sensor, cleaned associated connections. The Code Page says it will illuminate if the Vdc is above 4.9 or below 0.06 for 2 minutes at above 3000 RPM. I cant figure out how to test the sensors (an ohm-meter doesn't seem to work) and i cant figure out why the check engine light is still illuminated at idle given the parameters in the code page. Any thoughts are greatly appreciated.
