R
I have a 2010 M8 with a Cutler Stage II Turbo and the Attitude EFI control box.
Problem is I'm maxed out on fuel at 8 to 9#'s of boost.
Would like to be able to run a little more boost on occasion (wud ad 120RG to suit).
Option #1 - buy the Cutler dual injector throttle bodies, extra injectors and new Attitude controller for dual injectors.
Option #2 - I have a set of M1000 injectors and a newer PCV with Autotune. I could add a Bosch 3 bar map sensor and wire that to the PCV (they now offer this as an option). The PCV has the ability to go negative and positive buffer values for the EFI map (wud have to lean out a bit at low and midrange with the bigger injectors). This setup allows to you run real time EFI with feedback from the wide band O2 sensor. You can program by Air/Fuel ratio and it will create the map for you.
I'm favoring Option #2 but have done some calling around. Nobody except Speedwerx is using this setup and they program it for a supercharger, not a turbo. So it looks like I'm writing my own map going this route.
PCV is very friendly with access to the complete EFI map. Also has a option for an accelerator pump function where you can program a burst and duration for additional fuel.
Any advice??
Any advice??
