So I recently bought a 08 m8 with a boondockers pump gas turbo. Sled flat out rips. But tends to load up on the bottom end. So much that it makes off and on through the trees tough as it doesn't want to clean out when wide open. Been around a few 09s with identical kits and installs and from everything i've seen and heard they run flawless.
So i'm wondering what if any the differences are between the 08 and 09 m8s? Mapping or anything else.
If the mapping is different, can the 08 be reflashed with an 09 map?
