so im trying to assemble this crooked new sled.
un aware of it being crooked im on my third design for drop brackets,
looked a little closer and its over 1/4 in off on the sidewall bends. as in the right running board is 1/4" higher than the left
so knowing there is no returning this for the second time i guess i will just have a dogleging sled.
so im pretty sure if i get everything in line with the driveshaft it will operate correctly? maby?
and the drive should be correct being it mounts to fresh stock new locations. the steering hoop is right as well and this is where im measureing from
took my small square and made a line beside the bolts, found center between them. measured back 9, 18, and 27 inches top and bottom and drew lines for reference points. squared a line from the first nine back to the center mark, then used a straight edge to trace that new line and continue it on to the rear past where the drop bracket will sit
both sides
now, i am terrible with tapes and rulers but it was looking pretty much correct or at least progressive. i have three of the four locations but the fourth is ay out againlooks way off but is that 1/4 from the tunnel just playin tricks with my eyes?
is there a better way? theres got to be?
originally i started with a template that rested on the bottom side of the top but with that bad break it really didnt work
any pointers accepted my brand new tunnel is looking like swiss cheese
both sides
