T
Yes it is a 162", is this a common place for them to crack? It's near the front idler wheel, was hoping to get a few more miles as is. Is this dangerous or a bad idea to run it? Bummer the weld didn't hold up for you...
The cracks seen immediately after are from the two metals cooling at separate rates. I welded my king cat rails, five years ago. The key is to warm everything evenly with a space heater or whatever you can. Weld it as warm as you can, and keep it warm. I keep an outside heat source on it for an extended period before letting it slowly cool to room temperature. If you hear a pop you rushed it.
Is this not posted in the 1M section? = King cat?
I was unaware it was a requirement to be welded by the unskilled and underequipped, my bad.
