Can You Put A 155 Under 146 with out tunnel ext ?
M
mod7x
New member
Dec 29, 2007
53
2
8
Hibbing MN
I would say no, a riding buddy put a 151 in his assult and it is almost to long, but it does fit, hope this helps.
J
joe julkowski
New member
Nov 11, 2008
97
2
8
42
Cook MN.
I would like to know the same thing and would the drivers have to be switched out. If so can you take those drivers on and off or do you just switch out the axel???
LPIdaho
271
83
IF,ID
yes because i know you can stick a 166 under a 155. :)
just tilt the snowflap mount up to clear it and your good.
sledhed
1,751
435
83
Lolo, Montana
If it is the same pitch then you should not need to change the drivers. The drivers on the Polaris IQ are pressed on / off, most if not all drivers are as far as I know...
M
MNIQR
460
45
I jammed a 159 in my 144 tunnel. The back of the track is about right under the back of the flap, im gonna put a 3" or so extension on it over the summer though.
