J
Well I got this 1200 running finally. Took it out on it's maiden voyage, and during the day noticed oil in the water, a lot of it. No coolant loss.
That night I drained the coolant and flushed the system. Got it all back together and went out the next day.
I noticed a small amount of white smoke in the morning but, chalked it up to condensation. Half way through the day I noticed some coolant on the ground after I sat for a while. Just about the same time I noticed white smoke again. Well it went downhill fast, lots of coolant loss and lots of white smoke. Ran out of water so we towed it out.
So here is my question. The motor is out and disassembled. Water pump seals are toast, both water and oil. Bushing is bad, water pump shaft is bad. So I found the loss of coolant. But, what about burning it. The head and base gasket were good.
Do you think that I could get enough water through the crank seals to burn? If so, now that the leak will be resolved, should I replace them? I am not interested at throwing good money at good parts, but I need to find where the coolant is getting into the engine..
Any thoughts?
Any thoughts?
