Boost pipe removal tips?
T
TheBreeze
1,970
518
Sussex, Wisconsin
Anyone taken the pipe of yet for any reason? Bumper install, etc? I just got my backwoods BMP bumper, and need to pull the pipe to install. I know I can get it off, but is there a preferred way to deal with the system for maximum ease of removal, and re-installation? The exhaust setup and mid dump/spring amount complicates things slightly,
SUMMITREV
311
75
Baker, OR
Just remove bypass tube and undo pipe springs. Leave turbo and can alone. Why you have pipe out put a washer under the bottom pipe rubber. This fixes the pipe rubbing on bumper issue.
goridedoo
3,868
3,544
If you don’t have a GOOD spring removal tool, get one. I spent the $40 or whatever the bikeman one costs, and it was 100% worth it.
Jeff95
127
25
Terrebonne, Oregon
The bottom spring at the Y-Pipe is a B&*tch! Used a spring puller with open end wrench to push puller around.
Yes on the spacer and I also spaced the clutch side of the bumper out with washer.
Look like it would be hard to remove can.
Maybe someone with a service manual could post some pictures of how to remove can.
