Boondocker D8 2008 small problem
mountainhorse
18,606
11,814
West Coast
www.laketahoeconcours.com
Who installed it?
Did you change the throttle cable?
Can you confirm that the throttle body arm is resting against the idle stop screw when the idle is off?
Have you checked for air leaks?
Did you disturb the TPS sensor at all?
Do you have any flashing check engine lights?
Y
Sep 6, 2008
514
46
WORLD
www.brani.org
i installed it!
no cable change
i can confirm it, it is resting on the idle stop (checked it today)
air leaks? where?
TPS is ok. no disturbing. works fine
no light flashing. sled works fine
From the beginning sled got over 2000 idle RPM but now i have 2700 this is to much. i can not change to reverse. to high RPM
