Nearly Perfect Blue 2003 RX-1M Absolutely Dialed and Loaded with extras!
2003 Yamaha RX-1 Mountain
Sled is a one owner machine that has been babied its entire life and is in absolutely excellent condition with all the best modifications. The sled is super reliable, tuned to perfection and sure to impress! With the Shockwave helix, the sled will turn 10,500 RPM (Target shift speed with ECP/K&N filters) lower elevations (parking lot) and with a couple twists of the adjustment ring it spins 10,500 RPM at altitude climbing. I have my tunning notebook from every ride on this sled since it was new in November of 2002, detailing every change made to this sled. Perfectly prepped for a turbo if one should desire. I really have no idea of how much weight I have removed from this sled but, it has to be roughly 100 lbs because every light weight mod (except removing the light pod) has been done.
2,400 Adult Only Miles
New Boss color matched High Rise Seat with LED tail light
Wildchild Rider Forward Modification with Nytro Mountain Riser
Lightweight Arctic Cat M-7 Rear skid with Zero Pro Shocks and Holz relocation brackets
Rear skid set back providing an awesome track approach angle
Two Wheel rear Axle for improved side hilling (still in package)
Conservatively Ported 162 x 16 x 2 ½” Camoplast Extreme Track
Hartman Tunnel Extension and Custom lightweight Aluminum Drop Down Brackets
Lightweight Under Tunnel Single Exhaust Increases Power and Sounds incredible
ECP Carb Filters/Velocity stacks for Added Torque and Horse Power
Timing advanced 3 degrees for increased power via slotting of ignition pickup
Holz Lightweight Chromoly A Arms and Steering Rods
Heavy Hitter Adjustable Clutch Weights
Shockwave Adjustable Helix makes it quick and easy to raise or lower helix angle
Holz Lightweight Brake Rotor
Holzman ATACC Altitude and Temperature Compensator
Holtzman Carb Springs - multiple color spring sets
Lightweight Yuasa Custom Mounted Battery
Yamaha Apex Mountain Skis
Yamaha Blue Skid Plate
Custom Bar Mounted Speedometer - works perfectly!
Wahl Brothers 8 tooth Extrovert Drivers
Left Handed Throttle
Holz Racing Mountain Bar
12 Volt Accessory Outlet - for your GPS, etc
Anti Stab Idler Wheel kit
Custom Blue Cobra Windshield
Lighted Water Temperature Gauge
Yamaha Side Covers
Blue Hand Guards
Blue Bar End Hooks
New Nytro Mountain rear flap and also a Yamaha Blue shortie
Blue non slip foot well edging
Blue tunnel traction Brackets
Yamaha Blue Billet Gas Cap
Yamaha Service Manual
Tunning handbook(s) - from day 1
Blue Zenon high intensity bulbs
Sway bar removed don't need it with Holtz front end (but comes with sled)
Serviced with Mobile 1 0-40 synthetic oil
E Brake system - stops vehicle is you happen to fall off sled
Extremely compact jumper cables- just in case
Matching Yamaha Factory Genisis Extreme Deluxe Cover
Matching new Fly Backpack with hydro pack
Matching Yamaha/Reima size large jacket
Matching Yamaha/Reima size medium long bibs
$ 4,250
Or I will sell it for $3,999 but, if so, I will keep the Holtzman ATACC, the Shockwave adjustable helix and the Heavy Hitters for my Son's Mountain Max. I would replace the Shockwave with a Dalton 54/42 or stock 42 degree helix. The Heavy Hitters would be replaced with 8DN-00, 8DN-10 or 8BU-10 weights.
Please send me a PM if interested.
Yamaha Side Covers
Blue Hand Guards
Blue Bar End Hooks
$ 4,250
