Axys @ 3,200 miles Engine?
Ryan-41
523
Cheyenne, Wyoming
www.myspace.com
Hey guys just looking for some opinions, I have a 2018 Axys sidekick, the top end was done at 1,500 miles and it runs strong, but now at 3,200 miles, I am starting to worry about the bottom end. What would you guys check or possibly do? Do I need to throw another top end in it before the season starts? Just looking for some advice from people that know more than I do.
Thank you,
Ryan
208_RMK
255
56
Idaho
Thank you,
Ryan
Compression check- see what spec is for your elevation. If it passes run it, if not put some pistons and rings in it.
A
815
Elko, NV.
My experience is re-piston and re-ring every 1,800 miles. I have personally not had an 800 run more than 2,000 miles in the last 10 years. You may have compression and all will look great on the skirts, but what you can't see is the loose upper ring retaining pin that is about to fall out.
Ax-ski
New member
22
3
3
58701
I bought one last winter with I think 2500 miles if i remember right and I never batted a eye.
tuneman
1,167
1,205
Minnesota
www.everettsports.net
On my turbo '18, I put pistons in at 3500 miles. It now has 4100 miles. You can do a leak down test, but it's challenging to do on a 2 stroke. At a minimum, do a compression check. A bearing going bad on the bottom end will often show up with uneven or low compression. Could also measure squish to see if it's even.
Sage Crusher
3,270
1,196
Rock Springs,Wyoming
I caught a bad ( ready to go) wrist pin bearing-during a teardown of 2100 miles...
Ran perfectly- zero issues, but deicide after a good result from leak down test- I thought.... Meh !! - It didn't owe me a thing
Personally- 1800miles, and it's served a guy well- keep pushing it out there and it could be more expensive than you hoped for.
L
lymer
New member
Apr 5, 2022
11
2
3
menominee, mi
I waited too long and blew a piston at 4500 miles on my 2018 Assault 800. It was a costly mistake. Don't wait. 1800 miles is probably a good rule of thumb.
