Avid or Powder freaks center drive drivers on Axys turbo?
madmax
3,146
Salt lake city
I would use the dual extroverts on a turbo. On the center drive you still have to run a little tighter to not have the extros slip out of the rubber center holes. With the higher power of the turbo I feel like the extros lock into the metal tracks clips better without slipping. The center rubber holes can deform a little when the extro engages aggressively allowing the center to be more prone to slippage. On a NA sled they are good. To answer your question, either avid or powder freaks are good, if you live in the us avid, in Canada PF.
Billrmk
New member
49
2
8
Newport,WA
Went with the Avids. Great customer service. I pressed them on a little funky and he talked me through the fix. No vibration and no more ratchet. I did fully clip the track because I was seeing wear on the unclipped windows.
