V
Much better now. 250 front, 150 rear.Any chance to test and give an update on what you found you liked on ARO spring rates?
Thing about 100-125 for rear spring.
Awsome thankyou i am looking them up tonight any part number i can maybe look up and call them need them shipped to CanadaSouthwest speed
Thank youHere's the page we ordered from.
Southwest Speed - Performance Auto Parts
Huge Inventory of Parts for Street, Racing, & Off-Road Applications. One Stop Shop for Performance Auto Parts at the Lowest Prices. Order Online or By Phone.www.southwestspeed.com
I recently bought a 2017 rmx450z w a 2018 aro-20le. I noticed the previous owner drilled new holes in the tunnel to mount the rear suspension about an inch higher. What effect would this cause to the suspension characteristics? Should i put it back to stock?
Dude... I appreciate the level of detail and precision you're going for but it's not that exact of a need. I use a caliper to measure the 3/4 up scribe an arc with the caliper drill the top of the arc. I've done 3 of them that way and they all are straight. There no ideler wheels or anything on there warranting it being perfect to the thousandth.
So you are saying just make an arc 3/4" up from the center of the factory hole and drill the highest point of the arc?
600 psi pump on order. Thanks!RMR might well take that on, they do a lot of snowbike suspension setup - very well I might add. I'd give them a call.
On the other hand sending that thing to 350 - 375psi works fine tbh. Get a pump that goes to 400 and try that before you get carried away with valving changes - imo.
How do I buy your handle bar mount?timbersled.com has sprockets from 17 to 19 tooth. I have also found that KTM countershaft sprockets kind of fit. I'm running a 16 tooth from a ktm lc4 Dual Sport on my Drive axle and it slides right on but on the jackshaft it's pretty tight and I have to hammer it on so results May Vary.
To move the bars back I use a 2in Rox riser at a 45° angle rearward.I'm selling these for 50 bucks if you're interested they have the rubber anti-vibration mounts so they twist pretty easy if you crash but the solid version is available on eBay.
