the edge front torque arm is longer, the iq front torque arm is 5/8 s narrower but can be fitted to either tunnel have 2010 swit/back skid in o4 edge chassy weld .30 about 3/8 of tubing onto torque arm for width, then used a different allumin inside shaft, had turned it down about .010 diameter just to give a little clearance so the shaft wouldnt bind and keeping the bolts through the tunnel from wanting to back out. hope this helps, you can make anything fit, but the only problem is doing this stuff in the summer its warm and the days are long, but you really cant test til the white stuff flys
