Arctic cat m/cf/f/snopro parts clean out
hd4rob
1,066
373
83
Lake Park, MN
Completely selling anything and everything I have for m series. As of Aug 20 this is what I have. I will be updating as I keep cleaning shelves. Ask if you don't see something you need. I have pretty much two of everything after having 6 different crossfires and m's. Just pm with an email address or phone number to send pictures. I'm also completely parting a 06 m7 all is available.
Brand new m/cf green front bumper with bdx intake kit venting done, no intake $90
Brand new never installed mountain fit green/black side panel vents $60
Arctic Cat 700 laydown engine, good shape 1 cylinder/piston sold and recoil is sold, all else is available pm me with needs
Green crossfire left and right belly pans $70
Green m/cf left and right side panels $50
M/cf 700 driven clutch complete with helix, spring and brand new amp deflection adjuster $150
Crossfire gas tank(bigger than m) $100
M/cf 700 fuel pump assembly and all in tank valves. Complete intsall and plug in. $200
M/cf brake master cylinder assembly and calipers
$100
M/cf 700 steering post $20
Complete M7 throttlebodies rack with injectors $200
M7 stator $150
M7 primary wiring harness $100
M7 diamond drive, good shape $350
M7 drive shaft assembly $100
Cf/m7 y pipe $25
Cf 700 stock can $20
Yellow C&A razor skis with carbides $200
Code:
05-08 m/cf taillight and housing $15
05-08 m/cf rear cooler $25
M/cf tank cowl $25
Good 046 belt $20
M 1000 vforce reeds used very little for testing in a M8 $100
06 m/cf ECU $225
Bikeman silencer for AC Prowler XTZ 1000 $100
04 sno pro mod chain case assembly with brake assembly $125
F7 APV servo motor $100
3 m/cf/f dog bone a arm braces $10 for all 3
Complete m/cf intake, hood all the way to the throttle bodies $40
Intake accordion hoses for m/cf/f and clamps make an offer
Stock f7 can $15
Stock 11 m8 can, not 1 hour of run time, $30
Stock rear suspension shocks from 06 crossfire, both front track with spring and rear shock $100
Black firecat flyscreen $30 fits m/cf
