Even if the problem is not the exhaust valve cables, which it still may be,
buy a cat clutch puller tool for that model clutch because you will need to
replace the bushings/washers/and stay bolts on the primary clutch pins every 350-450 miles for good performance and to preserve the clutch integrity, Also a good opportunity to inspect all clutch parts condition at that time. Blow the clutches out with compressed air after every ride.
The clutch weights should be stamped on the side of the weight, if not you will need to weigh them individually on a gram scale. The shop that sells the weight
can recommend which way to go with the gram denomination for target rpm.
