Anybody swapped motors in an '01 sno pro?
mattymac
8,819
1,001
Sutter Ca.
Pretty simple as far as mounting goes, the cats are by far the easiest to do (with similar year motors) just get the donor motor and all the mounts used durring that year of the sled (most are the same) youll need the clutch offset tools and figure out your center to center for whatever belt needed, MEASURE TWICE AND DRILL ONCE through the rubber motor mounts to the bulkhead. Its easy just take your time!
What motor are you putting in?
BeeDoo
450
91
UT
My brother put a 700 in his 2001 Sno Pro.
The mounts weren't too bad to do, but that's what took some time.
You can go to arcticchat.com and do a search -- many have done it.
His handle over there is iambroke, he'd answer some questions if you need advice.
