adjusting oil pump on 06 m7
C
Im giong to adjust the oil pump but you turn out the screw
that goes into the oil pump that goes through the bracket arm or
lengthen were the cable comes out and there is the two nuts like on
a throttle cable if that makes sence.
Vern
2,455
1,285
hyrum utah
depends if its efi or carb. carb model has an adjuster inlign right up on the throttle block in front of the steering post. efi just have linkage that goes from the throttlebodies down to the oil pump and that is what you adjust. just disconnect it from the oil pump arm and unscrew however far you have determined it needs.
