900 Twin Wont Start, Any Ideas?
sprockethead
52
Northern UT
900 1M, put reeds back in, carbs and air box. Sled started right up, pulled it to the shop door to load in the trailer and it just died. Pulled it over many times and it does nothing. Changed plugs, swapped out ecu, and coil with ones from another 900, nothing. Well I guess its time to look at the stator or is there something else I'm missing? Thanks, Sprocket.
sprockethead
52
Northern UT
NO SPARK!
PolarisDude how r things in SF? I was there for 3 months last year working at the ANG at Joe Foss Field. They were some good peeps there.
Idcatman3
MODERATOR: Premium Member
866
Idaho Falls, Idaho
Did you unplug the chassis wiring harness to eliminate that as a possible problem? Throttle safety switch, key/kill switch etc. Also, did you try the parts you took off on a running 900?
mattymac
8,819
999
Sutter Ca.
sounds like you pinched your fuel line coming from either the fuel pump or tank (assuming its carbed) when you put your airbox back in.
Oct 6, 2009
8
LaGrande, OR
I just had the same problem last year man and it was the stator. hope that helps
Posted from Snowestonline.com App for Android
sprockethead
52
Northern UT
It was the voltage regulator. Its connectors were all corroded to he!!. Changed it out and runs like a champ again now. I would have never thought of it, but we had already changed out everything else electrically.
