V
what will happen if anything, if i take the outter insulation cover off of the stock pipe? will it affect anything if i leave it off and run it with out it?
yeah if its ceramic coated its fine because that holds in heat like the stock heat shields read the first post all he wants to do is pull the heat sheild which will effect power!
I thought the same thing about ceramic coating, had it done on other sleds before with great results. But when I got my 900 exhaust done it turned into a knightmare. I discovered with mine it has to be run with the shields. VJ_M might be okay but test it first if you do get it coated.
