900 RMK oil pump adjustment?
Gmiller
928
232
Breckenridge Colorado
My sled is running lean on the top end and rich on the bottom, which way would i adjust my pump to even it out? Making the line go down or making it go up?
Thanks
Grant
E
Ex-Member
ACCOUNT CLOSED
Mar 14, 2007
45,084
1,681
How do you know it is being lubed too much in the bottom end?
my thoughts exactly. Lines on the oil pump should be aligned when the throttle's at idle. If the fuel mix is incorrect, you've got bigger issues than an oil pump since that machine's fuel injected.
Have you had it reflashed? Updates done? Plugged injector/fuel line/fuel filter?
What's piston wash look like?
M
Sep 19, 2008
192
10
18
Green River Wyoming
yip had same probleme with my 05 it has a 975 kit on burned it down and couldnt figure out why in fact no one could tell me why. but I rebuilt it and reflashed the ecu and have not had a problem since so if I was you I would do a reflash and check your oil pump cable. I have had two oil pump cables brake good luck
Gmiller
928
232
I guess i should make myself more clear! When im running 3/4 throttle and up my plugs lean out to a white color, when im running below that my plugs are a brown/black color, My other guess would be TPS setting is off, but i DO have all updates and i just rebuilt the top end! Piston wash is perfect and oil pump cable looks brand new! Sled runs like a raped ape so my only complain is the lean condition when hill climbing!
Thanks
Grant
M
Sep 19, 2008
192
10
18
Green River Wyoming
Thanks
Grant
yes in deed that is the same problem I was haveing the only thing I changed after the rebuild was a reflash it was fixed.if it was tps I would think it would do it all the time but any thing is possible. you could also go to somebody that has the computer to read your codes so you knew what was going on their should be a fault code popping up.I burned mine down on the top end on a big freekin hill.good luck
donbrown
1,017
Los Angeles
Thanks
Grant
Okay ... now I understand.
Gmiller
928
232
Throttle body boots are BRAND NEW, did them along with the rebuild! Talked to the motorsports place today, $180 dollars for a reflash, should i go some place else? Anyone know of any GOOD polaris dealers in Colorado?
E
Ex-Member
ACCOUNT CLOSED
Mar 14, 2007
45,084
1,681
^ Woudln't recommend vickery, bad experience with them. Xtreme-castle rock was good, but that was previous owners. Can't say now.
B
benamen
Feb 21, 2008
191
25
Western Canada
Had my 900 reflashed in January at a cost of $40.00, but had to go out of town to get that price. Dealer in neighbouring town was able to do it the same day I called and for $40.00. Local dealer wanted $100 and could not get to it for a week. Saved some money and got an extra weekend of riding in.
