850/800 secondary clutch offset
ZRP Engineering
737
382
Utah
These are the belt witness marks. They should be the same on both sides of the belt.
What is the proper way to read this mark?
My belt shows the marks being slightly higher on the outside of the belt vs the inside (motor side)
Sent from my SM-G950U using Tapatalk
TRS
Life Member
4,129
6,291
Cody, WY
What is your base measurement now? You will need to start there. You could be .100” out.
General rule, needs to come out.
Killer Time Racing
996
223
Lower Michigan
I'll just keep changing the inserts each year then.
Who has the best price?
Is there any advantage with using PTO inserts on the mag side as well?
Also, did Northstar Rick offer harder durometer motor mount rubbers?
That's 800 and I have a full set of brand new here with torque arm if anyone is going to the dealer ..FS!
sledhead9825
1,195
416
83
Tony
Do you now how much you add to the measurement for the electric start ring gear?
Thanks
tdorval
1,201
276
83
Red Lodge, MT
Went down to Tony’s last night to set alignment and the belt to sheave on the primary. I believe mine was almost .200 out, hopefully it helps with belt life! Will update after I get some miles back on it.
Thanks Tony!
Wheel House Motorsports
29,933
5,970
SW MT
OEM spec had my sled at the far outboard limit of spec. I was getting sub 100 miles per belt.
Moved out Per tonys spec as baseline and then using witness marks after first ride as reference shimmed .020" farther out for a total of .140" farther out then stock setup. My sled now is wearing belts perfectly evenly and im seeing WAY less clutch heat and belt wear. 200 miles on current belt and belt is looking awesome.
damx
1,837
1,178
So if the witness mark is bigger on the inside or engine side, the secondary needs to come out some more ?
Scott
Scott Stiegler
69,618
11,737
W Mont
I got 260 miles on my first belt. I am about 50 miles into belt #2.
I'd better check my alignment.
damx
1,837
1,178
Tony do you measure from the outside shiv of the secondary to front side of the key stock ? If so I need to come 0.088" out. Thanks
TRS
Life Member
4,129
6,291
Cody, WY
Bulletin
I found an exception today. I was fighting the 2.57” measurement. Ended up at 2.51”. Finally put my 191 bar on it. Lead in was inside of spec. So please watch your witness marks closely to get it adjusted for your sled.
2XM3
3,280
1,370
Bitteroot valley,MT
Whats the opinion of a LOT of "float" ?? Also anyone get the ninja tool on ebay ?? Right now using the .250 stock method i'm like .213 off, and have good belt life at 10 psi boost ??
QUOTE : below
we don't check adjust clutch alignment anymore. we float all Polaris driven clutches as much as possible. meaning only leaving shim's/washers behind the driven so it doesn't hit anything. remove the spring from the driven and put it back together and back on the shaft. open it up all the way and spin it to see how close it comes to grease fittings etc. always leave just one washer. you want .60 of float inward and outward from it being aligned. so minimum of .120 of float. up to .250 we run .250 on our pro-stock 600. it turns 10,500 rpm's.
matchrocket
209
69
Boise
Remove your belt and bridge the key stock across the backside of your primary. With your caliper measure from the key stock to the outside leading edge of your secondary. The measurement we have found that works is:
850. 2.57”
800. 2.60.
16" 800 w/o Electric Start. Witness marks on my (new gates) belt are (none) on the motor side, ~.125" on panel side.
I took a measurement and I am more than .25" SHORT of your recommended amount for the 800. What am I missing?
Measuring:
outside (panel side) of bar stock to the outside face of secondary (Panel side), clutch pushed in, no belt installed (Shouldn't matter).
NO spaces installed on the secondary between bearing and clutch except the required one from the factory (washer).
Last gates belt lasted 200 miles before it exploded, full discloser, I folded it. Sled down RPM currently. (7900 / 8000)
