380 mountain mini
7,933
6,698
800r doo motor.
Mocked up with a 136 track right now.
Planning a 155x3 with pro rmk skid.
LoudHandle
3,900
2,779
Valdez, AK
Looks good! Other than the Doo engine (gag, hurl).
If you want some lighter drive train parts PM or text me. I have a couple magnesium cases from that era that I modified to fit the lighter Wildwood caliper, Aluminum ceramic brake discs with 7075-T6 aluminum hub, Titanium jack shafts, Holz gun drilled Chromoly drive shaft, triple roller chain and aluminum sprockets. From my competitive hill climb days.
7,933
6,698
I'll see how i like the concept before adding mods I suppose......
I don't mind the doo 800r, little slow revving but makes respectable power.......
Plus i have about $200 total into the motor. :)
(Sold more parts:))
d1100t
1,814
400
Saskatchewan Canada
Very cool
Awesome job.
I really like the way this is turning out.
It looks radical.
Every time I see something like this it makes me wonder what it would be like with a cat laid down motor and bdx diamond lite drive.
Keep up the good work.
Your doing a great job!!!
skierh2o
111
23
I am wondering where your fueling this beast from?
I was expecting your exhaust outside the front like a 2-stroker mx bike and filling in the engine compartment with a tank?!
How much fuel do you plan on housing?
Super cool build!!
looking forward to seeing your progress!
Ryan
snow-seeker
82
Olds Alberta
Super cool build!!
Ryan
I was with you. Sort of. I was expecting the cylinders to be turned around on the cases so the intake could be routed up to the steering neck and the pipe out the back, and the tank under the seat.
7,933
6,698
Not so easy with the reeds mounting to the case.
And the cooling path through the cylinders would leave a super hot exhaust. Etc. Etc.
7,933
6,698
Super cool build!!
Ryan
Fuel in the bike tank and a mid sized tank on the tunnel with a transfer/vent hose. Probably 7-7.5 gallons total.
If I stick the pipe out the front that would put the motor forward into my legs.
Besides as it is now i can enclose the pipe and have consistent pipe temps.
7,933
6,698
Awesome job.
It looks radical.
I had a 2010 m8 in the garage and stared and measured quite a bit before selling the thing....... (spare sled)
The lay down motor plus the overall height of the pipe TB's etc would make the bike 5" taller than it is now to keep from sitting on the pipe. Believe me I wanted to make that work...........
