G
Here I came across this in another forum:
Looks like no turbo...
Summit: Deep snow riding and climbing, especially out West.
NEW Features Mountain‐specific!
REV‐XM platform variation.
tMotion rear suspension.
FlexEdge track technology.
REV‐XM body style.
REV‐XM mountain‐specific ergonomics.
New colorations.
SC‐5M 2 rear suspension on Sport package.
Value price on Summit Sport package.
Summit Sport
Model:
Summit Sport
Platform:
REV-XP platform .
Engine:
Power T.E.K. 800R (151hp) or 600 Carb.
Suspension:
SC-5M2 rear suspension, available track lengths of 146"(with 600 carb engine), 154"(with 800R Power T.E.X. engine).
HPG front shocks.
Motion control shocks.
Summit SP
Model:
Summit SP E-Tec 800
Platform:
REV-XM platform .
Engine:
E-Tec 800 163+ HP.
Suspension:
tMotion rear suspension, with 3 available track lengths, 146, 154, & 163".
HPG shocks.
NEW Features!
PowderMax short Rod track.
REV-XM body style.
Forward foot position.
REV-XM seat.
REV-XM handlebar controls.
Heated glove box.
Updated Multi-function analog/digital gauge with standard temperature gauge.
Black/Orange coloration.
Model:
Summit XP E-Tec 600
Platform:
REV-XP platform .
Engine:
E-Tec 600.
Suspension:
SC-5M rear suspension, with 2 available track lengths, 146 & 154".
HPG shocks.
Note: Summit SP with E-Tec 600 spring choice: Electric Start.
Summit X
Model:
Summit X
Note: Spring only order.
Platform:
REV-XM platform .
Engine:
E-Tec 800 163+ HP.
Suspension:
HPG Plus shocks.
NEW Features!
REV-XM body style.
REV-XM seat.
Heated glove box.
Note: Summit X spring choices: Electric Start.
Optional Accessories
Extreme Skid Plate
Prefilter Grill Kit
Powder Plow
Fuel Caddy & LinQ
SidePanel Vent Kit
Optional Sled Wraps
Danger
ReMix
Retrospect
Geo Square
REV-XM Features:
tMotion Rear Suspension
The tMotion rear suspension is a mountain specific skid-frame.A swiveling rear arm and split front arm allow the skid frame to flex laterally, reducing the sled's resistance to banking. A more rising rate motion adds capacity and comfort. A ball joint at the hidge between the rear arm and the drop link and split front arms enable the flex.
New Snow Flap
Not just cool looking but functional. "A hinge" in the center prevents it from interfering with the track when backing up.
LED Tail Light
Brighter then the previous incandescent version, and extremely low profile, give it a very high tech appearance.
REV-XM Seat
Moving from one side of the sled to the other is key to technical boondocking, and the REV-XM seat makes this easy thanks to its extremely compact design. It is very narrow at the front to add leverage, and to maximize comfort for smaller riders. An enclosed storage compartment is in the base behind the seat. It has an 0.8 gal capacity, and a shape that fits a water bottle, gloves or goggles quite easily.
FlexEdge Track Technology
The standard Summit tracks are 16" wide for added flotation, and traction, but the fiberglass reinforcing rods that go across the track are just 12 inches wide. This enables the two outside inches of track to flex, reducing the effort required to initiate a roll.
Running Boards
For more solid footing in deep snow, the running board snow evacuation holes have been increased by 87%. An extremely strong running board edge extrusion (three times stronger then the REV-XP extrusion) maintains the boards stiffness. The extrusion is also serrated to grip boots better.
Rigid Grab Strap
A new grab strap has just the correct angle and stiffness for leverage and feel.
Flat Gauge
The gauge cluster on the REV-XM console is mounted nearly flat for easy reading during stand-up riding.
Heated Glove Box
Positioned between the gauges and windshield, this new covered 1 gal. storage compartment is warmed by ambient heat from the engine compartment, making it the ideal spot to stash spare goggles or gloves.
REV-XM Body Style
Multiple origami-like surfaces are an evolution of the pure faceted design of the REV-XP, while varied textures add sophistication and interest. "Float" hood panels are functional, with key air ducts underneath. They also hide seams for a very premium look, including an overall positive curve, directional wedge, V hood. and signature facial expression.
REV-XM Side Panels
Side panels for the REV-XM are unique to the sled. They are powder-dynamically shaped to slide through the snow more easily, especially when the sled is on it's side. More rounded front and bottom edges allow for easier roll up in technical maneuvers. For the right mix of light weight and toughness, they are built from polypropylene.
Easy Engine Access
Owners who like to work on their sleds (and dealers) will appreciate how easy they can access the engine compartment. The entire hood/console/headlight/gauge assembly can be removed in minutes.
Dual Air Intake
Air intakes are placed on the side of the headlights, by being very high on the machine, and very vertical, snow build-up is minimized for freer breathing. The intake and manifold design, and a new sound deadener significantly reduce noise to the driver.
Front Bumper
Even the front bumper is shaped to comfortably fit a gloved hand when you need to grab the front end while stuck.
A-Arm/Ski Spindle Boot Grip
REV-XM sleds have boot grips on the A-arm where it attaches to the top of the ski-spindle to provide a forward boot perch. Some riders want to get so far forward in extreme slow speed moves on the sled, that they have one leg on the running board, and another on the top of the ski spindle.
Forward Foot Position
Today's new technical riders want as much room to move around as possible for getting into, and out of unusual positions. The structural "stirrup" and side panel insert of the REV-XM platform are designed so that riders can place their feet eight inches further forward on the running boards, compared to the REV-XP. This places places more weight on the front end, which is key to slow speed maneuvers. In addition to giving the rider more room to operate, this enables the rider to stand on the same axis as the steering post, adding leverage in pulling the sled on it's side.
REV-XM Handlebar Controls
To reduce any interference in acrobatic maneuvers, the handlebar controls are reduced to their absolute minimum, and are exclusive to the REV-XM platform. The left hand control only includes the electric start/RER button (designed to prevent inadvertent activation) and the high beam switch. Hand and throttle warmer switches are relocated out-of-the-way, on the console.
Extreme Mountain
Freeride: Extreme off-*trail and deep snow riding.
Freeride
Model:
Freeride
Platform:
REV-XP RS chassis.
Forward steering post.
Engine:
E-Tec 800 163+ HP.
Suspension:
SC-5M-2 rear suspension (154,146" track).
SC-5 rear suspension (137" track).
KYB Pro 40 piggy-back racing shocks.
137 (1.75 in lugs), 146, & 154" (2.5 in lugs) track lengths.
NEW Features!
Available in‐season.
One track option with 146 and 154 versions (371 and 391cm)owderMax II with 2.5‐inch (6.4 cm)lugs.
Standard temperature gauge.
Squadron Green/Day‐glo orange coloration.
FREERIDE SPRING CHOICES
Electric Start (with no rewind starter).
Graphic Wrap (Available as a Spring promotion incentive choice).
Crossover
Renegade: High performance trail riding AND off‐trail boondocking.
Renegade Sport
Model:
Renegade Sport
Platform:
REV-X platform .
Engine:
ACE 600 or 550 Fan.
Suspension:
137 in SC-5m rear suspension with Cobra 137x15x1.25" track.
NEW Features!
REV-XP X seat.
Renegade Adrenaline
Model:
Renegade Adrenaline
Platform:
REV-X platform .
Engine:
E-Tech 800R, E-Tech 600 HO, or 4-Tec 1200.
Suspension:
137 rMotion rear suspension with RipSaw 137x15x1.25" track.
HPG Plusshocks.
NEW Features!
rMotion rear suspension.
REV-XP X seat.
eDrive pully (on 4-Tec 1200 equipped sleds only).
Renegade X
Model:
Renegade X
Note: Spring order only.
Platform:
REV-XS platform.
Engine:
E-Tech 800R, E-Tech 600 HO.
Suspension:
137 rMotion rear suspension with RipSaw 137x16x1.25 inch track.
HPG Plus R front shocks.
KYB pro 36 rear shock with the HPG Plus center shock.
NEW Features!
REV-XS platform.
137" rMotion rear suspension.
Heated glove box.
Temperature gauge (standard equipment now).
Snow flap.
LED tail light.
Dual air intake.
Renegade X Spring Choices
rMotion quick adjust system.
Electric start.
Ice ripper XT 137x16x1.25 inch track.
Graphic wrap kits.
Model:
Renegade X
Platform:
REV-XR platform.
Engine:
4-TEC 1200
Suspension:
NEW Features!
eDrive 2 clutch (for 4-Tec 1200 4 stroke engine only).
Graphic wrap kits.
Optional Sled Wraps
Carbon
Light Flash
Bring It Back
Geo Square
Renegade Backcountry
Model:
Platform:
REV-XP platform.
Engine:
Suspension:
137 rMotion rear suspension with PowderMax 137x16x1.75 inch track.
HPG Plus front shocks.
HPG rear shocks.
NEW Features!
Renegade Backcountry Spring Choices
Electric start.
Renegade Backcountry X
Model:
Platform:
REV-XS platform.
Engine:
Suspension:
KYB Pro 36 rear shocks.
NEW Features!
Forward foot position (same as summit).
Heated glove box.
Temp gauge (standard now).
Snow flap.
LED tail light.
Dual air intake.
Electric start.
Charger track 137x16x1.5 in.
Graphic wrap.
Optional Sled Wraps
Carbon
Light Flash
Bring It Back
Geo Square
Trail
Economy
MXZ: High performance trail riding, especially rough trails.
MXZ Sport
Model:
MXZ Sport
Platform:
REV-X platform.
Engine:
ACE 600, 600 carb, & 550 Fan.
Suspension:
SC-5 rear suspension with RipSaw 120x15x1.25 (1.0 with ACE 600) inch track.
Spring Choices
Electric start (600 carb & 550 fan engines. Standard with ACE 600)
MXZ TNT
Model:
MXZ TNT
Platforms:
REV-XS (E-Tec 800R), REV-XP (E-Tec 600 HO) & REV-XR(4-Tec 1200) platforms.
Engines:
E-Tec 800R, E-Tec 600 HO, & 4-Tec 1200.
Suspension:
rMotion rear suspension with RipSaw 120x15x1.25 inch track.
HPG Plus shocks front & rear.
NEW Features!
REV-XS platform.
Heated Glove box (800 E-Tec).
Snow flap (800 E-Tec).
LED taillight (800 E-Tec).
Electric start standard now (800 E-Tec).
Performance
MXZ-X
Model:
MXZ X
(Spring order only)
Platforms:
REV-XS (E-Tec 800R) & (E-Tec 600 HO) & REV-XR (4-Tec 1200) platforms.
Engines:
Suspension:
Premium shock package (HPG Plus shocks front & center & KYB Pro 36 shocks rear featuring Easy Adjustment Knob).
NEW Features!
REV-XS platform.
Heated Glove box (E-Tec).
Snow flap (E-Tec).
LED taillight (E-Tec).
Temperature gauge standard.
Spring Choices
Electric start (E-Tec).
Ice Ripper XT track 120x15x1.25 in.
Optional Sled Wraps.
Carbon
Light Flash
Bring It Back
Geo Square
MXZ-XRS
Model:
MXZ X-RS
Platforms:
REV-XP RS chassis.
Engines:
E-Tec 800R, E-Tec 600 HO.
Suspension:
KYB Pro 40 piggy-back racing shocks, featuring Easy Adjustment Compression Damping Knob on all four shocks.
NEW Features!
Electric start standard with E-Tec 600.
Revamped premium handlebar controls.
Spring Choices
Electric start (E-Tec 800).
Performance Touring & Trail
GSX: High performance groomed trail riding with luxury features.
GSX-LE
Model:
GSX LE
Platforms:
REV-XP (with E-Tec 600) & REV XR (with 4-Tec 1200) platform.
Engine:
E-Tec 600 HO & 4-Tec 1200 delivering 130HP.
Suspension:
SC-5 rear suspension with RipSaw 120x15x1.25 inch track.
Sport performance shock package ( HPG front shocks, Motion control center shock, and HPG-VR rear shock).
NEW Features!
GSX-SE
Model:
GSX SE
Platform:
REV-XR platform.
Engine:
E-Tec 800R, E-Tec 600 HO & 4-Tec 1200.
Suspension:
SC-5 137 rear suspension with RipSaw 137x15x1.25 inch track.
Air Control Suspension (ACS).
HPG front & center shocks.
NEW Features!
Magnesium coloration with orange accents.
Luxury Touring & Trail
Grand Touring: Luxurious and comfortable groomed trail riding with a passenger.
Grand Touring Sport
Model:
Grand Touring Sport
Platform:
REV-XP platform.
Engine:
ACE 600, 600 Carb, 550 Fan.
Suspension:
SC-5M rear suspension with 137x15x1 inch track.
Motion Control shocks.
NEW Features!
White/black coloration.
Grand Touring LE
Model:
Grand Touring LE
Platform:
REV-XR platform.
Engine:
Suspension:
SC-5M rear suspension with SilenTrack 137x15x1 inch track.
HPG front shocks.
HPG-VR rear shock.
NEW Features!
Grand Touring SE
Model:
Grand Touring SE
Platform:
REV-XR platform.
Engine:
Suspension:
SC-5 rear suspension with SilenTrack 137x15x1 inch track.
HPG front shocks.
HPG center shock.
NEW Features!
Hybrid white coloration choice.
Utility
Pleasure Utility
Expedition: Ride trails for pleasure, off-*‐trail exploring, work tasks.
Expedition
Models:
SE (Spring Only), LE & Sport.
Platforms:
SE in REV-XU, LE in REV-XU, Sport in XP.
Engine:
SE & LE either E-tec 600 or 4-Tec 1200, Sport either Ace 600 or 550 Fan.
Suspension:
SE & LE, SC-5U Suspension with 154x20x1.25track.
Sport, SC-5U rear suspension with 154x16x1.5in. track.
SE has (ACS) Air control suspension,Motion control HPG shocks, Dual A-arm front suspension.
LE has Dual A-Arm front suspension, HPG Front center shocks.
Note: SE SPRING ORDER ONLY.
NEW Features!
eDrive 2 drive pulley(4-*‐TEC 1200 engine choice).
Windshield mirrors.(SE)
One*piece windshield.(SE)
Upgraded appearanceSE)
Light Utility
Tundra: Light utility; deep snow riding.
Tundra
Models:
Tundra Extreme,Tundra LT, & Tundra Sport.
Platforms:
Tundra Extreme, Tundra LT, Tundra Sport in REV-X & Tundra body style.
Engine:
Tundra Extreme has E-Tec 600, Tundra LT & Tundra Sport either Ace 600 or 550 Fan.
Suspension:
Tundra Extrme has SC-5U Suspension with 154x16x2.25 powder max track.
Tundra LT has SC-5U rear suspension with 154x16x1.5in. track.
Tundra Sport has SC-5U rear suspension with 137x16x1.25in. track.
All have a 32 inch wide ski stance.
NEW Features!
eDrive 2 drive pulley(Rotac Ace 600 engine choice).
Heavy Duty Utility
Skandic: Utility applications.
Skandic
Models:
SWT, WT.
Platforms:
SWT & WT in REV-X platform, with the Skandic body style.
Engine:
SWT has E-Tec 600 or Ace 600 & WT either E-Tec 600, Ace 600 or 550 Fan.
Suspension:
SWT has SC-5U Suspension with 154x24x1.25 track.
WT has SC-5U rear suspension with 154x20x1.5in. track.
Both have the LTS front suspension.
Youth
No specific model yet.
REV‐XM body style.
New colorations.
Summit Sport
Model:
Summit Sport
Platform:
REV-XP platform .
Engine:
Suspension:
HPG front shocks.
Summit SP
Model:
Summit SP E-Tec 800
Platform:
REV-XM platform .
Engine:
E-Tec 800 163+ HP.
Suspension:
HPG shocks.
NEW Features!
REV-XM body style.
REV-XM seat.
Heated glove box.
Model:
Summit XP E-Tec 600
Platform:
REV-XP platform .
Engine:
E-Tec 600.
Suspension:
HPG shocks.
Summit X
Model:
Summit X
Platform:
REV-XM platform .
Engine:
E-Tec 800 163+ HP.
Suspension:
HPG Plus shocks.
NEW Features!
REV-XM body style.
REV-XM seat.
Heated glove box.
Extreme Skid Plate
Prefilter Grill Kit
Powder Plow
Fuel Caddy & LinQ
SidePanel Vent Kit
Optional Sled Wraps
Danger
ReMix
Retrospect
Geo Square
REV-XM Features:
New Snow Flap
LED Tail Light
REV-XM Seat
Running Boards
Rigid Grab Strap
Flat Gauge
Heated Glove Box
REV-XM Body Style
REV-XM Side Panels
Easy Engine Access
Dual Air Intake
Front Bumper
Extreme Mountain
Freeride
Model:
Freeride
Platform:
REV-XP RS chassis.
Engine:
E-Tec 800 163+ HP.
Suspension:
NEW Features!
Crossover
Renegade Sport
Model:
Renegade Sport
Platform:
REV-X platform .
Engine:
ACE 600 or 550 Fan.
Suspension:
NEW Features!
REV-XP X seat.
Renegade Adrenaline
Model:
Renegade Adrenaline
Platform:
REV-X platform .
Engine:
Suspension:
HPG Plusshocks.
NEW Features!
REV-XP X seat.
Renegade X
Model:
Renegade X
Platform:
REV-XS platform.
Engine:
Suspension:
NEW Features!
REV-XS platform.
Heated glove box.
Snow flap.
LED tail light.
Dual air intake.
Electric start.
Graphic wrap kits.
Model:
Renegade X
Platform:
REV-XR platform.
Engine:
4-TEC 1200
Suspension:
NEW Features!
Graphic wrap kits.
Optional Sled Wraps
Carbon
Light Flash
Bring It Back
Geo Square
Model:
Platform:
REV-XP platform.
Engine:
Suspension:
HPG rear shocks.
NEW Features!
Electric start.
Model:
Platform:
REV-XS platform.
Engine:
Suspension:
NEW Features!
Heated glove box.
Snow flap.
LED tail light.
Dual air intake.
Electric start.
Graphic wrap.
Optional Sled Wraps
Carbon
Light Flash
Bring It Back
Geo Square
Trail
Economy
MXZ Sport
Model:
MXZ Sport
Platform:
REV-X platform.
Engine:
Suspension:
Spring Choices
MXZ TNT
Model:
MXZ TNT
Platforms:
Engines:
Suspension:
NEW Features!
REV-XS platform.
Performance
MXZ-X
Model:
MXZ X
(Spring order only)
Platforms:
Engines:
Suspension:
NEW Features!
REV-XS platform.
Snow flap (E-Tec).
Spring Choices
Carbon
Light Flash
Bring It Back
Geo Square
MXZ-XRS
Model:
MXZ X-RS
Platforms:
REV-XP RS chassis.
Engines:
Suspension:
NEW Features!
Spring Choices
GSX-LE
Model:
GSX LE
Platforms:
Engine:
Suspension:
NEW Features!
GSX-SE
Model:
GSX SE
Platform:
REV-XR platform.
Engine:
Suspension:
NEW Features!
Grand Touring Sport
Model:
Grand Touring Sport
Platform:
REV-XP platform.
Engine:
Suspension:
NEW Features!
Grand Touring LE
Model:
Grand Touring LE
Platform:
REV-XR platform.
Engine:
Suspension:
HPG front shocks.
HPG-VR rear shock.
NEW Features!
Grand Touring SE
Model:
Grand Touring SE
Platform:
REV-XR platform.
Engine:
Suspension:
HPG front shocks.
HPG center shock.
NEW Features!
Utility
Pleasure Utility
Expedition
Models:
Platforms:
Engine:
Suspension:
NEW Features!
Light Utility
Tundra
Models:
Platforms:
Engine:
Suspension:
NEW Features!
Heavy Duty Utility
Skandic
Models:
SWT, WT.
Platforms:
Engine:
Suspension:
Youth
