F
Hey guys trying to narrow down an issue with my 2012 Proclimb. While riding last week I started to get a misfire at 6000 RPM. Thought it was plugs so I replaced those......no change. Unfortunately, it's not throwing a code. Yesterday I tore into trying to find the issue. This is what I've already done or checked.
-Drive clutch full rebuild
-Driven clutch full rebuild
-TPS delete with tether
-New plugs
-Air sensor relocate
-Injectors - Tested and Cleaned
-V-Force 3 reeds - Checked (look like new)
-Servo motor - works as it should
-Power valves - Cleaned and work as they should
-Great compression - Pistons and cylinder walls look great
-Checked all connectors under the hood
The sled is acting like I'm hitting a Rev limiter at 6000+ RPM. How does the quad plug setup work? From what I can see on the Cat Service Manual, there are primary and secondary coils. Do these fire at different times in the RPM range? How would I go about testing the coils? Also wonder about the stator.
The sled is very snappy and runs great up until the 6000 RPM mark. Any help on what direction to go would be great.
-New plugs
