2010 IQ RMK 144 tie rod end replacement
polrmk
39
6
8
Goodhue, MN
My 2010 IQ RMK needs new tie rod ends. To get at the ends in the center of the sled, do you take the boots off? Thanks.
whoisthatguy
812
248
From looking at Carl's Cycle parts catolog, it looks like you pull the engine otherwise it would be impossible to undo a nut off of the spinning bolt, by accessing through the boot hole. It usually requires a 1/2" wrench to the bolt shaft beneath the nut, in order to loosen the nut. If the bolt with spherical ball end is not loose, then you just unscrew the tie rod from the entire center assembly, and reattach a new tie rod. Which is also how you remove a bent tie rod, prior to heating and straightening it, should they become bent. One end of the tie rod is reverse threaded.
