So, I happened upon a 2003 Arctic Cat Mountain 900 yesterday and long story short... I ended up buying it sight unseen for $500.
I got there today and handlebars were not connected to skis or steering linkage. From the looks of it, it looks like there is a washer/nut missing from the linkage to the bottom of the steering column. If so, how would one get the linkage to connect it up? It's directly under the engine with only around .75" of space to get to it... can I remove the pan under the engine (basically drill out the pop rivets, etc) to access the steering components? I sure hope the engine doesn't need to come out to put a single nut on the linkage?
Here is a video I took showing the two parts disconnected:
https://photos.app.goo.gl/rJhOmgI57jvJu8Xw2
Sorry for terrible angles, but I just can't get a great angle. First part of the video is the steering column moving freely... second part was me moving the ski linkage. There is a hole on far side (you can't see it in video) on the steering column knuckle that has a perfectly size hole for that linkage bolt. Seems to be too convenient not to mate up?
A bit of background on the sled (after I just said long story short above... ). The seller was a landlord who was tired of looking after a ex tenants snowmobile for the past 3 years. She'd been asking him to pick it up and he was blowing her off and basically abandoned it. She said "I just want it gone!" ... I asked if it ran and she said "Yes, my son started last year but noticed oil under the hood, so didn't want to run it long." Sure enough, it had some oil under the hood, but the tank was still full, so I'm guessing the previous owner was just shaky when filling because it seems like it's in decent shape. All fluids are where they should be (coolant, crank case, 2 cycle oil) The crank moves fine and all seems to be in good order other than a broken pull starter cord and steering.
I bought it as a project and figured worse comes to worse, it's seized up and I'd be a be able to do my first bottom to top engine rebuild! So far it does NOT look like it's seized up at all, but the previous owner didn't know how to fix the steering, so just stopped riding it. Hopefully this is a win for me?
Edit: so I'm sure this is the correct connection. Anyone know the size of nut I'd need? Looks very finely threaded... Would a Teflon but be suitable?
