2002 Mountain Cat with Cutler 1150
ranger12
522
333
Dickinson ND
2002 Mountain Cat Mod $6000 OBO
This sled is in great shape. It has always been stored inside, it's clean and in perfect running condition.
Specifics:
1150 Cutler racing engine
Balanced welded and pinned crankshaft
CPC racing carbs 48mm
TPS sensor block
CPC throttle block
CPC billet intake manifolds
CPC advanced ignition timing key
light weight balance shaft
VForce 3 Reeds
900 oil pump
900 high altitude ECU
Lightweight bulk head
Boss seat
Lightweight brake Rotor
Chrome molly steering post
Chrome molly drive shaft
Chrome molly A-arms
Exhaust gas technologies Avenger 2
EGTs, water temp, rpms and thumb switch
Steel braided brake line
4" Rox riser
8 tooth extrovert drivers
Van Amberg hill climb tunnel
light weight brake rotor
chain case guard
Paragon secondary
New primary clutch
left hand throttle
dropped and rolled chain case
Holz hill climb rear suspension
Camoplast track 162"x 2 1/2"
20/39 or 19/40 gearing
This is a very light weight sled with roughly 700 miles on it. The motor is approximately 230 hp. It is set up right now for 6000ft and above. If you've ever talked to anyone that's had one of these sleds, they'll likely tell you it's the most fun sled they've EVER owned! I've never had a problem with it. It runs excellent!
I had a neck injury and will not be able to ride this year so I decided to sell my sleds if I can get a good price for them. Serious inquiries may call or text me at 701 260-9695.My sleds are very well cared for and maintained. I'm 45 years old and don't abuse them.
ranger12
522
333
Dickinson ND
I have a set of all Black Powder Pro skis with the right saddles that will go to the person buying this sled. That is at least a $400 value.:light:
snowmanx
2,163
442
83
54
Polson, Montana
I had an 1150 cutler in a ski doo zx chassis. It was a blast. Sometimes I wish I still had it.
Nice sled, good luck
ranger12
522
333
Dickinson ND
For what its worth. Last year when I had my 15 Prolite 940 for sale a guy asked if he could take it for a ride while I had it up at Bear Lodge. I started this sled and told him that I would go with for a short rip. After he got done testing the Prolite he asked if he could ride the sled I was on. When he came back he said that this old sled would kick the Prolites butt as far as power goes.
N
May 20, 2021
1
US
Specifics:
TPS sensor block
CPC throttle block
VForce 3 Reeds
900 oil pump
Boss seat
Chrome molly A-arms
4" Rox riser
chain case guard
Paragon secondary
New primary clutch
left hand throttle
Hi! My mechanic just finished my 04 Cat 900/ Cutler 1150 w hi compression heads. How hard is yours to pull start?
Sent from my SM-J737V using Tapatalk
