2.6 to 3.0 Axys Track Swap
H
HandoEX
7
North Dakota
Sled 1: 2016 Pro RMK 155x 2.6 (2.86 pitch), quickdrive belt, pump gas turbo
Sled 2: 2016 Pro RMK SC 155x3.0 (3.0 pitch), chaincase, stock
Looking to purchase sled two this weekend and I’d really like to swap the tracks on these two sleds.
Can the drivers can be swapped from the driveshaft on the 3.0 track to the shaft on the 2.6 track and vice versa? Or would I need to buy afternarket drivers?
Jun 30, 2017
89
39
rails are a 156 for the 3” sled, rails are closer to 154 on a 2.6 sled. might be able to squeeze the broke in track on the longer rails. the drivers should be able to swap. can double check drive shafts are the same on babbits
Pickin’ Boogers
392
326
You can't switch the drivers but you can switch the driveshafts along with their drivers. Sled 1 is a hex shaft and sled 2 is splined. Bearings are the same and they swap over just fine. Migrate the lower QD/chain sprocket bolt along with the shaft (one is shorter than the other).
