1999 700 into a 2002 edge 800 ple
J
Feb 27, 2021
1
Vermont
I recently blew my 2002 xc sp 800 up. Half of the water pump side piston skirt went into the crankcase so the engine is not worth rebuilding so I bought a 700 out of a 1999 gen 2 chassis. The problem I am having is the wiring harness does not match at the plug in right out of the engine. The biggest connector is the same but the two smaller ones are completely different. On the 800 there is two small connectors with 3 wires each. The 700 has two smaller connectors one with three wires and one with two. Can I swap the stators under the flywheel or do I have to get a wiring harness to match the 700?
R
Feb 10, 2010
32
Did you get the CDI/coil with the 700, I think you are going to need them. I have a 97 700 that I have had in a Gen ll and now an edge chassis, seemed like it was plug and play on both.
