13 silber 800 clutch set up help
mtncat1
2,356
655
south jordan ut.
hey guys i'm new to the turbo game and i need some help .
i have a 13 800 pro with a base silber kit with flashed ecm at 10 lbs , i have ran the sled a couple of times. the sled is only turning 7500 rpm .and kind of feels like its not shifting out at higher speeds.
the set up is as follows
primary ; pink spring with 76 gram team weights
secondary ; i have a 48 deg helix with the stock secondary spring .
from what silber recommends i need a 44-48.36 helix with a orange black spring .
does this sound right and does anyone have one they could let go of ?
diamonddave
Chilly’s Mentor
5,578
3,893
Wokeville, WA.
What elevation are you running at?
diamonddave
Chilly’s Mentor
5,578
3,893
Wokeville, WA.
sorry 7 to 10000
I would try dropping your primary weight first at least 2 possibly 3-4 grams.
A few years ago I was running 77.5 grams/pink with something close to your current helix but with a 2863 turbo at 4,000-6,000 ft.
Are you running stock drivers, track, and gearing?
mtncat1
2,356
655
south jordan ut.
i ran it today i took 3 grams total out of the tip of the weight that got me to 8100 rpm on first stab of the throttle with it droping to 7900 during a short pull. i have stock gears with 7 tooth drivers and a x3 track . thanks for replying bth i appreciate it .
