Hi all. I have a 09 M8 with 600 miles on. Recently I have noticed excess oil on and around the secondary clutch. Upon removing the aluminum end cap from the clutch, I found some buildup of oil on the O-ring. The clutch retaining bolt had no oil on at the threads, which would lead me to believe the oil was not comming out the vent, the cut out threads on bolt. The only other place for the oil to come out, is... the input shaft seal. The seal looks fine while the unit is assembled. I drained the oil, it looks to be the right amount, but dark. This is my second DD sled. I have had ZERO DD issues with my other sled with 2900 miles. Anyway, the dealer wants me to bring it in and I do not have much time before we leave for a trip.
Has anyone else seen this seal leak? Could the inside, output seal be letting water in? Could the vent not be functioning?
Thanks.
Thanks.
